Dear Community,
I am bringing up an iMX8M Plus based board having 1GB DDR capacity :
root@viperimx8mp:~# free
total used free shared buff/cache available
Mem: 968116 115580 771180 10556 81356 761580
Swap: 0 0 0
I also adjusted the memory layout in custom .dtsi as below :
+#include "imx8mp.dtsi"
+ memory@40000000 {
+ device_type = "memory";
+ reg = <0x0 0x40000000 0 0x40000000>;
+ resmem: reserved-memory {
+ #address-cells = <2>;
+ #size-cells = <2>;
+ ranges;
+ ocram: ocram@900000 {
+ no-map;
+ reg = <0 0x900000 0 0x70000>;
+ * Memory reserved for optee usage. Please do not use.
+ * This will be automaticky added to dtb if OP-TEE is installed.
+ * optee@56000000 {
+ * reg = <0 0x56000000 0 0x2000000>;
+ * no-map;
+ /* global autoconfigured region for contiguous allocations */
+ linux,cma {
+ compatible = "shared-dma-pool";
+ reusable;
+ size = <0 0x3c000000>;
+ alloc-ranges = <0 0x40000000 0 0x40000000>;
+ linux,cma-default;
+ dsp_reserved: dsp@92400000 {
+ reg = <0 0x92400000 0 0x1000000>;
+ no-map;
+ dsp_reserved_heap: dsp_reserved_heap {
+ reg = <0 0x93400000 0 0xef0000>;
+ no-map;
+ dsp_vdev0vring0: vdev0vring0@942f0000 {
+ reg = <0 0x942f0000 0 0x8000>;
+ no-map;
+ dsp_vdev0vring1: vdev0vring1@942f8000 {
+ reg = <0 0x942f8000 0 0x8000>;
+ no-map;
+ dsp_vdev0buffer: vdev0buffer@94300000 {
+ reg = <0 0x94300000 0 0x100000>;
+ no-map;
+ /* used only by tuning tool, can be removed for normal case */
+ isp0_reserved: isp0@94400000 {
+ no-map;
+ reg = <0 0x94400000 0 0x10000000>;
However, I still have the following error :
root@viperimx8mp:~# dmesg | grep cma
[ 0.000000] OF: reserved mem: failed to allocate memory for node 'linux,cma'
[ 0.000000] cma: Reserved 32 MiB at 0x000000007c000000
[ 0.000000] Memory: 932468K/1015808K available (17920K kernel code, 1506K rwdata, 6920K rodata, 2880K init, 553K bss, 50572K reserved, 32768K cma-reserved)
Could anybody help to configure the memory layout to avoid this problem, please ? I am using BSP LF-5.10.52-2.1.0.
Thanks in advance and best regards,
Khang
解決済! 解決策の投稿を見る。
I think I found the root cause: allocating 960MB for CMA over 1GB of memory seems not practical.
K.
K.
