Hardware name: NXP i.MX8MPlus EVK board (DT)
urn the immage on sd card using this step-/yocto/imx-yocto-bsp/build-xwayland/tmp/deploy/images/imx8mp-lpddr4-evk$ zstdcat imx-image-full-imx8mp-lpddr4-evk-20230825110715.rootfs.wic.zst | sudo dd of=/dev/sdb bs=1M conv=fsync
Hi @shahin22!
Please follow the steps of the chapter "4.2 Universal update utility" or chapter "4.3 Preparing an SD/MMC card to boot" in our Linux user guide, those chapters describe how to deploy the system using the uuu or with Linux commands.
https://www.nxp.com/docs/en/user-guide/IMX_LINUX_USERS_GUIDE.pdf
If the problem persists, I recommend checking using our precompiled images if you made a modification in the Yocto Project.
Best Regards!
Chavira
Were you able to solve this issue, i have same.
Thank you for contacting NXP Support!
What board are you using?
What steps are you using to write the SD card?
I recommend using the UUU to deploy the system on your board.
Best Regards!
Chavira
