Hello
I am using imx6ul evk board and we prepared a customized board on imx6ul and we want to integrate EMMC16G-TB29-90F01 eMMC. Can you please share the info on how to integrate EMMC16G-TB29-90F01 eMMC in linux device tree and how to configure the eMMC .
Thanks and Regards
Shammi
Hi igor,
I have gone through the eMMC datasheet but i can't find the OCR internal register, But i have found the CID, CSD, EXT_CSD registers. Where do i have to make changes. Is it in kernel or U-boot ? Can you tell me the file name in which i have to make changes?
Thanks & Regards
Shamiullah
Hi Shammi
new emmc can work without additional customizations as it is supported
in i.MX6UL EVK design and software:
Hi igor,
I am using EMMC16G-TB29-90F01 eMMC. The size is 16GB . Without ?any changes how can it detects the properties of EMMC16G-TB29-90F01 eMMC . Can you explain me why no changes is required in device tree and uboot?
Thanks and Regards
shammi
properties of EMMC16G-TB29-90F01 eMMC and other eMMC are obtained reading its
internal registers like: OCR, CID, CSD, EXT_CSD, they are described in emmc
specifcation : https://www.jedec.org/standards-documents/technology-focus-areas/flash-memory-ssds-ufs-emmc/e-mmc
Hi igor,
Thanks & Regards
Shamiullah
there is no need for manual changes, sd/mmc driver handles internal registers automatically,
Driver description can be found in sect.3.3 MMC/SD/SDIO Host i.MX Linux Reference Manual
