Wpa Supplicant Crashing while disconnect from connected Access Point
3,960件の閲覧回数
ThanarajS
Hi All,
   We have ported driver using NL80211 interface in Android 6 platform. Wi-Fi is up and connection established with Access point[Open/Secured].
After when we try to disconnect the connected Access point in android GUI, wpa_supplicant is crashing by signal 11.
Error Log:
action=android.net.conn.INET_CONDITION_ACTION
01-01 00:02:01.651   540   581 E WifiConfigStore:  rewrite network history for "Redmi"WPA_PSK
01-01 00:02:02.267  1273  1273 D wpa_supplicant: EAPOL: startWhen --> 0
01-01 00:02:02.267  1273  1273 D wpa_supplicant: EAPOL: disable timer tick
01-01 00:02:03.060   238   533 W audio_hw_primary: do_out_standby... -1243289856
01-01 00:02:03.385  1273  1273 D wpa_supplicant: wlan0: Control interface command 'IFNAME=wlan0 SIGNAL_POLL'
01-01 00:02:03.385  1273  1273 D wpa_supplicant: CTRL-DEBUG: ctrl_sock-sendto: sock=10 sndbuf=163840 outq=0 send_len=49
01-01 00:02:03.386   540   583 D ConnectivityService: updateNetworkScore for NetworkAgentInfo [WIFI () - 100] to 48
01-01 00:02:06.390  1273  1273 D wpa_supplicant: wlan0: Control interface command 'IFNAME=wlan0 SIGNAL_POLL'
01-01 00:02:06.390  1273  1273 D wpa_supplicant: CTRL-DEBUG: ctrl_sock-sendto: sock=10 sndbuf=163840 outq=0 send_len=49
01-01 00:02:06.392   540   583 D ConnectivityService: updateNetworkScore for NetworkAgentInfo [WIFI () - 100] to 46
01-01 00:02:08.949   540   583 D ConnectivityService: handlePromptUnvalidated 100
01-01 00:02:09.396  1273  1273 D wpa_supplicant: wlan0: Control interface command 'IFNAME=wlan0 SIGNAL_POLL'
01-01 00:02:09.397  1273  1273 D wpa_supplicant: CTRL-DEBUG: ctrl_sock-sendto: sock=10 sndbuf=163840 outq=0 send_len=49
01-01 00:02:09.398   540   583 D ConnectivityService: updateNetworkScore for NetworkAgentInfo [WIFI () - 100] to 44
01-01 00:02:11.264  1273  1273 D wpa_supplicant: wlan0: Control interface command 'IFNAME=wlan0 SCAN TYPE=ONLY'
01-01 00:02:11.264  1273  1273 D wpa_supplicant: wlan0: Setting scan request: 0.000000 sec
01-01 00:02:11.264  1273  1273 D wpa_supplicant: CTRL-DEBUG: ctrl_sock-sendto: sock=10 sndbuf=163840 outq=0 send_len=3
01-01 00:02:11.265  1273  1273 D wpa_supplicant: wlan0: Starting AP scan for wildcard SSID
01-01 00:02:11.265  1273  1273 D wpa_supplicant: wlan0: Add radio work 'scan'@0xb6bd90f0
01-01 00:02:11.265  1273  1273 D wpa_supplicant: wlan0: First radio work item in the queue - schedule start immediately
01-01 00:02:11.265  1273  1273 D wpa_supplicant: wlan0: Starting radio work 'scan'@0xb6bd90f0 after 0.000154 second wait
01-01 00:02:11.265  1273  1273 D wpa_supplicant: wlan0: nl80211: scan request
01-01 00:02:11.265  1273  1273 D wpa_supplicant: nl80211: Scan SSID - hexdump(len=0): [NULL]
01-01 00:02:11.265  1273  1273 D wpa_supplicant: nl80211: Scan extra IEs - hexdump(len=6): 7f 04 00 00 0a 02
01-01 00:02:11.266  1273  1273 D wpa_supplicant: Scan requested (ret=0) - scan timeout 30 seconds
01-01 00:02:11.266  1273  1273 D wpa_supplicant: RTM_NEWLINK: ifi_index=5 ifname=wlan0 wext ifi_family=0 ifi_flags=0x11043 ([UP][RUNNING][LOWE)
01-01 00:02:11.266  1273  1273 D wpa_supplicant: nl80211: Event message available
01-01 00:02:11.266  1273  1273 D wpa_supplicant: nl80211: Drv Event 33 (NL80211_CMD_TRIGGER_SCAN) received for wlan0
01-01 00:02:11.266  1273  1273 D wpa_supplicant: wlan0: nl80211: Scan trigger
01-01 00:02:11.266  1273  1273 D wpa_supplicant: wlan0: Event SCAN_STARTED (47) received
01-01 00:02:11.266  1273  1273 D wpa_supplicant: wlan0: Own scan request started a scan in 0.000576 seconds
01-01 00:02:11.266  1273  1273 D wpa_supplicant: CTRL-DEBUG: ctrl_sock-sendmsg: sock=10 sndbuf=163840 outq=448 send_len=24
01-01 00:02:11.267   540  1274 E WifiHW  : Received the following from the supplicant: <3>CTRL-EVENT-SCAN-STARTED
01-01 00:02:11.267  1273  1273 D wpa_supplicant: CTRL_IFACE monitor sent successfully to /data/misc/wifi/sockets/wpa_ctrl_540-6\x00
01-01 00:02:11.267  1273  1273 D wpa_supplicant: nl80211: Event message available
01-01 00:02:11.267  1273  1273 D wpa_supplicant: nl80211: Drv Event 34 (NL80211_CMD_NEW_SCAN_RESULTS) received for wlan0
01-01 00:02:11.267  1273  1273 D wpa_supplicant: wlan0: nl80211: New scan results available
01-01 00:02:11.267  1273  1273 D wpa_supplicant: nl80211: Scan probed for SSID ''
01-01 00:02:11.268  1273  1273 D wpa_supplicant: nl80211: Scan included frequencies: 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462 244
01-01 00:02:11.268  1273  1273 D wpa_supplicant: wlan0: Event SCAN_RESULTS (3) received
01-01 00:02:11.268  1273  1273 D wpa_supplicant: wlan0: Scan completed in 0.001481 seconds
01-01 00:02:11.268  1273  1273 D wpa_supplicant: nl80211: Associated on 2462 MHz
01-01 00:02:11.268  1273  1273 D wpa_supplicant: nl80211: Associated with 8c:be:be:3b:25:7b
01-01 00:02:11.268  1273  1273 D wpa_supplicant: nl80211: Received scan results (1 BSSes)
01-01 00:02:11.268  1273  1273 D wpa_supplicant: nl80211: Scan results indicate BSS status with 8c:be:be:3b:25:7b as associated
01-01 00:02:11.268  1273  1273 D wpa_supplicant: wlan0: BSS: Start scan result update 6
01-01 00:02:11.268  1273  1273 D wpa_supplicant: BSS: last_scan_res_used=1/32
01-01 00:02:11.269  1273  1273 D wpa_supplicant: wlan0: New scan results available (own=1 ext=0)
01-01 00:02:11.269  1273  1273 D wpa_supplicant: CTRL-DEBUG: ctrl_sock-sendmsg: sock=10 sndbuf=163840 outq=0 send_len=24
01-01 00:02:11.269   540  1274 E WifiHW  : Received the following from the supplicant: <3>CTRL-EVENT-SCAN-RESULTS
01-01 00:02:11.269  1273  1273 D wpa_supplicant: CTRL_IFACE monitor sent successfully to /data/misc/wifi/sockets/wpa_ctrl_540-6\x00
01-01 00:02:11.269  1273  1273 D wpa_supplicant: WPS: AP[0] c4:e9:84:88:9a:e2 type=0 tries=0 last_attempt=-1 sec ago blacklist=0
01-01 00:02:11.269  1273  1273 D wpa_supplicant: WPS: AP[1] b4:75:0e:cc:50:79 type=0 tries=0 last_attempt=-1 sec ago blacklist=0
01-01 00:02:11.270  1273  1273 D wpa_supplicant: wlan0: Radio work 'scan'@0xb6bd90f0 done in 0.004528 seconds
01-01 00:02:11.270  1273  1273 D wpa_supplicant: wlan0: Selecting BSS from priority group 1
01-01 00:02:11.270  1273  1273 D wpa_supplicant: wlan0: 0: 8c:be:be:3b:25:7b ssid='Redmi' wpa_ie_len=0 rsn_ie_len=20 caps=0x431 level=77
01-01 00:02:11.270  1273  1273 D wpa_supplicant: wlan0:    selected based on RSN IE
01-01 00:02:11.270  1273  1273 D wpa_supplicant: wlan0:    selected BSS 8c:be:be:3b:25:7b ssid='Redmi'
01-01 00:02:11.272  1273  1273 D wpa_supplicant: wlan0: Control interface command 'IFNAME=wlan0 BSS RANGE=0- MASK=0x29d87'
01-01 00:02:11.272  1273  1273 D wpa_supplicant: WPS: Unknown Vendor Extension (Vendor ID 9442)
01-01 00:02:11.276  1273  1273 D wpa_supplicant: CTRL-DEBUG: ctrl_sock-sendto: sock=10 sndbuf=163840 outq=0 send_len=3965
01-01 00:02:11.284  1273  1273 D wpa_supplicant: wlan0: Control interface command 'IFNAME=wlan0 STATUS-NO_EVENTS'
01-01 00:02:11.285  1273  1273 D wpa_supplicant: EAPOL: EAP Session-Id not available
01-01 00:02:11.285  1273  1273 D wpa_supplicant: CTRL-DEBUG: ctrl_sock-sendto: sock=10 sndbuf=163840 outq=0 send_len=233
01-01 00:02:12.400  1273  1273 D wpa_supplicant: wlan0: Control interface command 'IFNAME=wlan0 SIGNAL_POLL'
01-01 00:02:12.400  1273  1273 D wpa_supplicant: CTRL-DEBUG: ctrl_sock-sendto: sock=10 sndbuf=163840 outq=0 send_len=49
01-01 00:02:12.401   540   583 D ConnectivityService: updateNetworkScore for NetworkAgentInfo [WIFI () - 100] to 42
01-01 00:02:14.881   238   533 W audio_hw_primary: out_set_parameters routing=1024, ret 0, out -1243289856
01-01 00:02:14.891   238   533 I audio_hw_primary: start_output_stream_primary... -1243289856, device 1024
01-01 00:02:14.893   238   533 W audio_hw_primary: card 1, port 0 device 0x400
01-01 00:02:14.893   238   533 W audio_hw_primary: rate 44100, channel 2 period_size 0x300
01-01 00:02:15.166   232  1291 E BufferQueueProducer: [Redmi] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count
01-01 00:02:15.403  1273  1273 D wpa_supplicant: wlan0: Control interface command 'IFNAME=wlan0 SIGNAL_POLL'
01-01 00:02:15.404  1273  1273 D wpa_supplicant: CTRL-DEBUG: ctrl_sock-sendto: sock=10 sndbuf=163840 outq=0 send_len=49
01-01 00:02:15.406   540   583 D ConnectivityService: updateNetworkScore for NetworkAgentInfo [WIFI () - 100] to 40
01-01 00:02:15.663   540  1301 D NetlinkSocketObserver: NeighborEvent{elapsedMs=138500, 192.168.43.1, [8CBEBE3B257B], RTM_NEWNEIGH, NUD_STALE}
01-01 00:02:17.972   238   533 W audio_hw_primary: do_out_standby... -1243289856
01-01 00:02:18.059   238   533 W audio_hw_primary: out_set_parameters routing=1024, ret 0, out -1243289856
01-01 00:02:18.068   238   533 I audio_hw_primary: start_output_stream_primary... -1243289856, device 1024
01-01 00:02:18.069   238   533 W audio_hw_primary: card 1, port 0 device 0x400
01-01 00:02:18.069   238   533 W audio_hw_primary: rate 44100, channel 2 period_size 0x300
01-01 00:02:18.073   540   581 E WifiConfigStore: removeNetwork 0 key="Redmi"WPA_PSK config.id=0  crc=1087246119
01-01 00:02:18.079  1273  1273 D wpa_supplicant: wlan0: Control interface command 'IFNAME=wlan0 REMOVE_NETWORK 0'
01-01 00:02:18.079  1273  1273 D wpa_supplicant: CTRL_IFACE: REMOVE_NETWORK id=0
01-01 00:02:18.079  1273  1273 D wpa_supplicant: wlan0: Request to deauthenticate - bssid=8c:be:be:3b:25:7b pending_bssid=00:00:00:00:00:00 reD
01-01 00:02:18.079  1273  1273 D wpa_supplicant: TDLS: Tear down peers
01-01 00:02:18.079  1273  1273 D wpa_supplicant: wpa_driver_nl80211_disconnect(reason_code=3)
01-01 00:02:18.079  1273  1273 D wpa_supplicant: wlan0: Event DEAUTH (12) received
01-01 00:02:18.079  1273  1273 D wpa_supplicant: wlan0: Deauthentication notification
01-01 00:02:18.080  1273  1273 D wpa_supplicant: wlan0:  * reason 3 (locally generated)
01-01 00:02:18.080  1273  1273 D wpa_supplicant: Deauthentication frame IE(s) - hexdump(len=0): [NULL]
01-01 00:02:18.080  1273  1273 I wpa_supplicant: wlan0: CTRL-EVENT-DISCONNECTED bssid=8c:be:be:3b:25:7b reason=3 locally_generated=1
01-01 00:02:18.080  1273  1273 D wpa_supplicant: CTRL-DEBUG: ctrl_sock-sendmsg: sock=10 sndbuf=163840 outq=0 send_len=76
01-01 00:02:18.080  1273  1273 D wpa_supplicant: CTRL_IFACE monitor sent successfully to /data/misc/wifi/sockets/wpa_ctrl_540-6\x00
01-01 00:02:18.080  1273  1273 D wpa_supplicant: wlan0: Auto connect disabled: do not try to re-connect
01-01 00:02:18.080  1273  1273 D wpa_supplicant: wlan0: Ignore connection failure due to local request to disconnect
01-01 00:02:18.080  1273  1273 D wpa_supplicant: TDLS: Remove peers on disassociation
01-01 00:02:18.080  1273  1273 D wpa_supplicant: wlan0: WPA: Clear old PMK and PTK
01-01 00:02:18.080  1273  1273 D wpa_supplicant: wlan0: Disconnect event - remove keys
01-01 00:02:18.080  1273  1273 D wpa_supplicant: wpa_driver_nl80211_set_key: ifindex=5 (wlan0) alg=0 addr=0x0 key_idx=0 set_tx=0 seq_len=0 key0
01-01 00:02:18.080   540  1274 E WifiHW  : Received the following from the supplicant: <3>CTRL-EVENT-DISCONNECTED bssid=8c:be:be:3b:25:7b reas1
01-01 00:02:18.080  1273  1273 D wpa_supplicant: wpa_driver_nl80211_set_key: ifindex=5 (wlan0) alg=0 addr=0x0 key_idx=1 set_tx=0 seq_len=0 key0
01-01 00:02:18.080  1273  1273 D wpa_supplicant: wpa_driver_nl80211_set_key: ifindex=5 (wlan0) alg=0 addr=0xb6bf50b8 key_idx=0 set_tx=0 seq_le0
01-01 00:02:18.080  1273  1273 D wpa_supplicant:    addr=8c:be:be:3b:25:7b
01-01 00:02:18.080  1273  1273 D wpa_supplicant: wlan0: State: COMPLETED -> DISCONNECTED
01-01 00:02:18.081  1273  1273 D wpa_supplicant: nl80211: Set wlan0 operstate 1->0 (DORMANT)
01-01 00:02:18.081  1273  1273 D wpa_supplicant: netlink: Operstate: ifindex=5 linkmode=-1 (no change), operstate=5 (IF_OPER_DORMANT)
01-01 00:02:18.081  1273  1273 D wpa_supplicant: CTRL-DEBUG: ctrl_sock-sendmsg: sock=10 sndbuf=163840 outq=0 send_len=71
01-01 00:02:18.081  1273  1273 D wpa_supplicant: CTRL_IFACE monitor sent successfully to /data/misc/wifi/sockets/wpa_ctrl_540-6\x00
01-01 00:02:18.081  1273  1273 D wpa_supplicant: EAPOL: External notification - portEnabled=0
01-01 00:02:18.081   540  1274 E WifiHW  : Received the following from the supplicant: <3>CTRL-EVENT-STATE-CHANGE id=0 state=0 BSSID=8c:be:be:i
01-01 00:02:18.081  1273  1273 D wpa_supplicant: EAPOL: SUPP_PAE entering state DISCONNECTED
01-01 00:02:18.081  1273  1273 D wpa_supplicant: EAPOL: Supplicant port status: Unauthorized
01-01 00:02:18.081  1273  1273 D wpa_supplicant: nl80211: Skip set_supp_port(unauthorized) while not associated
01-01 00:02:18.081  1273  1273 D wpa_supplicant: EAPOL: SUPP_BE entering state INITIALIZE
01-01 00:02:18.081  1273  1273 D wpa_supplicant: EAPOL: External notification - portValid=0
01-01 00:02:18.081  1273  1273 D wpa_supplicant: EAPOL: External notification - EAP success=0
01-01 00:02:18.081  1273  1273 D wpa_supplicant: wlan0: State: DISCONNECTED -> DISCONNECTED
01-01 00:02:18.081  1273  1273 D wpa_supplicant: nl80211: Set wlan0 operstate 0->0 (DORMANT)
01-01 00:02:18.081  1273  1273 D wpa_supplicant: CTRL-DEBUG: ctrl_sock-sendto: sock=10 sndbuf=163840 outq=0 send_len=3
01-01 00:02:18.081  1273  1273 D wpa_supplicant: RTM_NEWLINK: ifi_index=5 ifname=wlan0 operstate=5 linkmode=1 ifi_family=0 ifi_flags=0x11003 ()
01-01 00:02:18.082  1273  1273 D wpa_supplicant: wlan0: Control interface command 'IFNAME=wlan0 SAVE_CONFIG'
01-01 00:02:18.082  1273  1273 D wpa_supplicant: Writing configuration file '/data/misc/wifi/wpa_supplicant.conf.tmp'
01-01 00:02:18.090   238   533 D AudioFlinger: mixer(0xb4200000) throttle end: throttle time(8)
01-01 00:02:18.140  1273  1273 D wpa_supplicant: Configuration file '/data/misc/wifi/wpa_supplicant.conf' written successfully
01-01 00:02:18.140  1273  1273 D wpa_supplicant: CTRL_IFACE: SAVE_CONFIG - Configuration updated
01-01 00:02:18.140  1273  1273 D wpa_supplicant: CTRL-DEBUG: ctrl_sock-sendto: sock=10 sndbuf=163840 outq=0 send_len=3
01-01 00:02:18.140  1273  1273 D wpa_supplicant: RTM_NEWLINK: ifi_index=5 ifname=wlan0 wext ifi_family=0 ifi_flags=0x11003 ([UP][LOWER_UP])
01-01 00:02:18.141  1273  1273 D wpa_supplicant: nl80211: Event message available
01-01 00:02:18.141  1273  1273 D wpa_supplicant: nl80211: Drv Event 48 (NL80211_CMD_DISCONNECT) received for wlan0
--------- beginning of crash
01-01 00:02:18.141  1273  1273 F libc    : Fatal signal 11 (SIGSEGV), code 1, fault addr 0x4 in tid 1273 (wpa_supplicant)
01-01 00:02:18.145   540   581 D WifiNative-HAL: stopRssiMonitoring, cmdId 0
01-01 00:02:18.147  1063  1208 D OpenGLRenderer: endAllStagingAnimators on 0x91c92180 (RippleDrawable) with handle 0xb3b3fcf0
01-01 00:02:18.242   236   236 F DEBUG   : *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
01-01 00:02:18.243   236   236 F DEBUG   : Build fingerprint: 'Freescale/sabresd_6dq/sabresd_6dq:6.0.1/2.1.0-ga-rc2/20160715:user/release-keys'
01-01 00:02:18.243   236   236 F DEBUG   : Revision: '0'
01-01 00:02:18.243   236   236 F DEBUG   : ABI: 'arm'
01-01 00:02:18.243   236   236 F DEBUG   : pid: 1273, tid: 1273, name: wpa_supplicant  >>> /system/bin/wpa_supplicant <<<
01-01 00:02:18.243   236   236 F DEBUG   : signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 0x4
01-01 00:02:18.244   540   606 W NativeCrashListener: Couldn't find ProcessRecord for pid 1273
01-01 00:02:18.249   236   236 F DEBUG   :     r0 00000004  r1 80000000  r2 00000000  r3 00000000
01-01 00:02:18.249   236   236 E DEBUG   : AM write failed: Broken pipe
01-01 00:02:18.249   236   236 F DEBUG   :     r4 b6bcb144  r5 b6bfa280  r6 b6bcf0e0  r7 00000000
01-01 00:02:18.249   236   236 F DEBUG   :     r8 b6bcf0f8  r9 7f705a1c  sl b6bcb130  fp b6b82000
01-01 00:02:18.249   236   236 F DEBUG   :     ip b6e2ac98  sp bef23048  lr b6e227c9  pc b6e227c8  cpsr 00010030
01-01 00:02:18.286   236   236 F DEBUG   :
01-01 00:02:18.286   236   236 F DEBUG   : backtrace:
01-01 00:02:18.286   236   236 F DEBUG   :     #00 pc 0000a7c8  /system/lib/libnl.so (nla_get_u16+5)
01-01 00:02:18.287   236   236 F DEBUG   :     #01 pc 000a7ec1  /system/bin/wpa_supplicant
01-01 00:02:18.287   236   236 F DEBUG   :     #02 pc 00007b67  /system/lib/libnl.so (nl_recvmsgs+650)
01-01 00:02:18.287   236   236 F DEBUG   :     #03 pc 0009be4d  /system/bin/wpa_supplicant
01-01 00:02:18.287   236   236 F DEBUG   :     #04 pc 000152fd  /system/bin/wpa_supplicant
01-01 00:02:18.287   236   236 F DEBUG   :     #05 pc 00015967  /system/bin/wpa_supplicant
01-01 00:02:18.287   236   236 F DEBUG   :     #06 pc 00091e2b  /system/bin/wpa_supplicant
01-01 00:02:18.287   236   236 F DEBUG   :     #07 pc 0000df2d  /system/bin/wpa_supplicant
01-01 00:02:18.287   236   236 F DEBUG   :     #08 pc 00017365  /system/lib/libc.so (__libc_init+44)
01-01 00:02:18.288   236   236 F DEBUG   :     #09 pc 0000dfd8  /system/bin/wpa_supplicant
01-01 00:02:18.347   236   236 F DEBUG   :
01-01 00:02:18.347   236   236 F DEBUG   : Tombstone written to: /data/tombstones/tombstone_02
01-01 00:02:18.348   540   556 I BootReceiver: Copying /data/tombstones/tombstone_02 to DropBox (SYSTEM_TOMBSTONE)
01-01 00:02:21.149   238   533 W audio_hw_primary: do_out_standby... -1243289856
01-01 00:02:28.156   540   581 D WifiHW  : 'IFNAME=wlan0 SET ps 1' command timed out.
01-01 00:02:28.158   235   523 D CommandListener: Clearing all IP addresses on wlan0
01-01 00:02:28.158   540  1302 D DhcpClient: Clearing IP address
01-01 00:02:28.162   540  1301 D NetlinkSocketObserver: NeighborEvent{elapsedMs=151000, 192.168.43.1, [8CBEBE3B257B], RTM_DELNEIGH, NUD_STALE}
01-01 00:02:28.173   235   523 D CommandListener: Setting iface cfg
01-01 00:02:28.183   540   583 D ConnectivityService: NetworkAgentInfo [WIFI () - 100] EVENT_NETWORK_INFO_CHANGED, going from CONNECTED to DISD
01-01 00:02:28.183   540   583 D ConnectivityService: NetworkAgentInfo [WIFI () - 100] got DISCONNECTED, was satisfying 2
01-01 00:02:28.185   540   581 D IpReachabilityMonitor: clear: iface{wlan0/5}, v{4}, ntable=[]
01-01 00:02:28.186   540   581 D WifiStateMachine: WifiStateMachine: Leaving Connected state
01-01 00:02:28.186   540   581 D IpReachabilityMonitor: clear: iface{wlan0/5}, v{5}, ntable=[]
01-01 00:02:28.192   540   581 D WifiNetworkAgent: NetworkAgent: NetworkAgent channel lost
01-01 00:02:28.198   540   583 D ConnectivityService: notifyType LOST for NetworkAgentInfo [WIFI () - 100]
01-01 00:02:28.212   540  1303 D DhcpClient: Receive thread stopped
01-01 00:02:28.268   235   523 V IdletimerController: runCmd(/system/bin/ip6tables -w -t raw -D idletimer_raw_PREROUTING -i wlan0 -j IDLETIMER0
01-01 00:02:28.334   235   523 V IdletimerController: runCmd(/system/bin/ip6tables -w -t mangle -D idletimer_mangle_POSTROUTING -o wlan0 -j ID0
01-01 00:02:28.338   540   583 D CSLegacyTypeTracker: Sending DISCONNECTED broadcast for type 1 NetworkAgentInfo [WIFI () - 100] isDefaultNetwe
01-01 00:02:28.339   540   583 D ConnectivityService: sendStickyBroadcast: action=android.net.conn.CONNECTIVITY_CHANGE
01-01 00:02:28.348   540   557 D Tethering: MasterInitialState.processMessage what=3
01-01 00:02:28.496   235   523 E Netd    : netlink response contains error (No such file or directory)
01-01 00:02:28.499   540   583 E ConnectivityService: EVENT_NETWORK_INFO_CHANGED from unknown NetworkAgent
We didnot change anything in wpa supplicant,eventhough its getting crashed.
Could you please suggestion idea to fix this crash?
Raj.
Thanaraj Subramani
ラベル(5)
2 返答(返信)
2,619件の閲覧回数
kiwei
我也遇到同样的问题,请问这最终解决了麽
2,619件の閲覧回数
igorpadykov
Hi Thanaraj
this can be debugged using AN4553 Using Open Source Debugging Tools for Linux on i.MX Processors
http://www.nxp.com/assets/documents/data/en/application-notes/AN4553.pdf
note, nxp has Professional Services helping to port drivers
http://www.nxp.com/support/nxp-professional-services:PROFESSIONAL-SERVICE
