What is the difference between Parameter Register's Frame Size and SAI Transmit Configuration 4 Register 's Frame Size?
1,070件の閲覧回数
machengyuan
Thank you.
939件の閲覧回数
igorpadykov
Hi ma
Parameter Register's (read only) shows sai configuration implemented in that processor:
for example FRAME (Frame Size) =5 : The maximum number of slots per frame is 2^FRAME: 32
This corresponds description for SAI Transmit Configuration 4 Register (TCR4):
"FRSZ -The maximum supported frame size is 32 words."
4 返答(返信)
939件の閲覧回数
machengyuan
Thank you very much!
939件の閲覧回数
machengyuan
So Parameter Register's   Frame Size is only going to be 5 at most, even if it has 4 bits, right?
939件の閲覧回数
igorpadykov
Parameter Register shows what max. Frame Size is implemented in
that processor silicon sai module. In other processors silicons it may have other values.
940件の閲覧回数
igorpadykov
Hi ma
