Hi All,
Am using Imx 6Q sabre SDP board.i need load to WEC7 using Uboot. When i try to use Display is not getting.
DDIPU is not getting called.
Is there any setting missing regarding to display when i use uboot?
Rizwan Syed
I understand, please check the link. to find where to modify the IVT table in order to UBOOT to have the proper link to start.
Hi James
IVT comes in bootloader right. But for me drivers are getting loaded SD,USB and display is not coming.
Rizwan Syed
Hello Rizwan,
NXP does not support WEC but I think you are not using the correct IVT Table in Eboot to download from Uboot you can take a look at :
Hi james
Actually am not using Eboot. I am using Uboot and NK through fatload and go commands.
Rizwan Syed
