I am working on IMXRT1170-EVK and I took the example of "USB_Host_CDC".
(Note : I had a another board IMXRT1064-EVK configured as USB_Device and took the Example of "USB_Device_CDC_Vcom").
Q1 : When I ran the SDK I am able get the data for every 10ms over USB_Host_cdc , after some time SDK code getting Crashed.
Q2: Any hardware changes are required for High speed on USB ?
Can you help me this issue?
已解决! 转到解答。
Hi @smartpavan333 ,
I made a same test, RT1170EVK+RT1050EVKB. It works fine. The RT1170EVK doesn't crash after a long time. Did you change anything? I think there is no hardware change required for high speed, the demo is high speed mode by default.
Jing
Hi @smartpavan333 ,
Jing
