Thermal Management Guidelines for i.MX8M Mini
ko-hey
Senior Contributor II
Hi all,
I'm finding thermal management guidelines for i.MX8MMini.
I found only following document but it's for i.MX6 series.
https://www.nxp.com/docs/en/application-note/AN4579.pdf
Is there any document for i.MX8M series especially for i.MX8MMini ?
Ko-hey
art
There are no specific thermal management guidelines for the i.MX8M series processors.
As the basic concept, the application note document you're referring to is applicable to i.MX8M series processors as well.
Artur
mrudangshelat1
Hi Ko-hey,
There is no specific thermal guideline document for i.MX8M series. As per i.MX 8M EVK Board Hardware User's Guide, "the EVK thermal design was performed for a typical use case. Ensure your thermal design is based on your specific use case."
Mrudang
