I want to use a Micron Dual Die NAND Flash(MT29F64G08AEC) in synchronous mode on an DualLite i.MX6.
For both DQS lines i can't seem to find any info on how to connect these to NANDF_DQS(SD4_DAT0.alt2 on i.MX6)
Can i simply gang both DQS pin on the memory device(which i also did with the DQ-x Datalines and control logic interface ,except Chip Select)
Solved! Go to Solution.
Hi Arne
according to datasheet this nand is dual die with separate cs, dqs signals so
your understanding is correct.
Hello Igor,
thank you for this reply!
regards
Hi Arne
