Sticky Bit error of i.MX6Solo with using debugger
1,003 次查看
yuuki
Senior Contributor II
Dear All,
In our original board, we accessed the EIM_CS0 area(0x0800_0000-) by using JTAG.
However, when we access the EIM_CS0 area after a system Boot from SD, Sticky Bit error occurs.
Word access and double word access were tried, but it was the same result.
May I have any advice to evade this error?
Yuuki
标记 (3)
870 次查看
igorpadykov
Hi Yuuki
had you set CCM_CGPR6, CG5 for EIM clock enabling ?
871 次查看
igorpadykov
Hi Yuuki
870 次查看
yuuki
Dear igor-san,
Thank you very much for your support.
I found CG5 field of the CCM_CCGR6 register having been 00.
The problem was solved by setting this value to "11".
Yuuki
