I'd like to know if it is possible to send 4K video through DSI as the followings.
"The datasheet indicates that using DSI achieves FHD 60fps, while HDMI achieves 4K 60fps. Is it possible to compress and transmit 4K video via the DSI interface using formats like DSC 1.2 or DSC 1.1?"
Thank you.
Andy
Solved! Go to Solution.
Yes, is possible but you must get at 4k 30fps maximum for tx
Thanks for your confirmation.
Andy
