Hi meton,
Where did you get the WEC7 BSP for i.MX6? Can the SD port used to read SD/MMC card?
B.R
Justin.
Hi Justin,
I'm trying on a 4.2.2 android, using an i.mx6 quad board.
Yes, the SD port can be used to read from a SD card.
Hi Meton,
I got confused about your issue. Is this issue only happen on WEC7 or both Android/WEC7 have this issue?
B.R
Justin
Hi meton,
I saw you write WEC7. Which board are you using. On Freescale i.MX6 Sabre SD board we can use the SDIO WIFI card.
B.R
Qwerty
We are sorry for getting back to you so late. Are you still stuck with the issue? If you have somehow to resolved the
issue, can we close the discussion? If you still need help, please feel free to reply with an update to this discussion.
Yixing
Hi Yixing,
yes we still have the issue.
Hi Meton
I will branch your question to internal group and assign an engineer to work on it.
Yixing
