I am using i.MX7D with Linux 4.9 kernel. I am configuring UART as a RS485. I am trying to transfer 0x0A data over serial but at the receive end I am getting extra 0x0d byte. (i.e transmitting 0x0a - receiving 0x0d 0x0a ). I went through some forums (see below link.) I got some idea why it is happening but I am unable to solve the issue. Can you please guide me.
link : c - UNIX send CR rather than LF - Stack Overflow ,
Thanks in advance.
Deven
Hi DEVEN
one can try to decrease baud rate, add delays between sending data to transmitter
and disable sdma (if it is used in the case).
