Porting KSZ9031RN to imx6
1,636 次查看
bastien
Hello !
I am working on imx6 processor custom board, i added the KSZ9031 phy Ethernet on the board.
Recommendations in the post Porting KSZ9031 to i.MX BSP gives the phy side schematic only.
I am not sure if i correctly connected the RGMII_INT pin (p38) to the imx6 (see attached pictures).
Thank you
1,621 次查看
jimmychan
I use this PHY in a i.MX7D board design. I connected this INT pin to a gpio in case we may check the INT output signal in future. For normal using, we don't need to care this INT signal.
1,622 次查看
jimmychan
