Dear all,
I have a problem to display the video file in the i.MX25.
I'm using the MPlayer to display the video file.
But the dispaly speed is slow.
So I checked the MPlayer profile for the source Video file.
In the profile, I had been found the YUV to RGB conversion had much load in the MPlayer.
The simple profile contents are like below. For the detailed, refer to the attach file. (mplayer_profile_1.txt)
I think I could reduce the load of YUV2RGB function if I optimize the MPlayer to the i.MX25 core.
The i.MX257 core is ARM9, and the model number is "ARM926EJ-S".
Could you tell me the MPlayer Configuration options for i.MX257 ARM Core?
Eric.
Original Attachment has been moved to: mplayer_profile_1.txt.zip
已解决! 转到解答。
