Hi All,
I want to use GPIO_SD_B1_05 to 08 (GPIO port 3 ) as interrupts which will trigger a interrupt on raising edge on MIMXRT1024 running Linux. Can anybody please share any reference DTS file to achieve the same. Do I need to make any other changes in driver etc other than the DTS entry. Thanks in advance.
Babu
解決済! 解決策の投稿を見る。
Hi @sbabu ,
Do you mean, your RT1024 code is based on linux os? RT1024 can't support the linux, it can use the freertos.
Or your use the linux gcc to compile the RT1024 code?
Until now, we still don't have the linux DTS for the RT1024.
Wish it helps you!
Kerry
Hi @sbabu ,
Wish it helps you!
Kerry
@kerryzhou - Thanks. No worries. We will check on it.
