Now, we are designing our evaluation board circuit using iMX8QX.
So we want to know the following specification for LPDDR4 Layout Design Guide Line.
1.Line Length Difference (Differential Pair P/N, CK/DQS)
2.Line Length Difference (Single - ended, CS/CKE/DMI/CA/DQ)
3.Space between Differential Pair and Other Traces
- CK_t/c to CAx, CS_n
- CK_t/c to CKEx
- CK_t/c to DQSx_t/c
- DQS_t/c to DQ
- DMI to DQ
4.Characteristic Impedance (Z0)
5.Differential Impedance (Z0_diff)
Thanks a lot
Yoshihiro
Hi Yuri,
May I have a copy of the guide doc in pdf? Could you send me through email if it is available to send. Thank you.
I've sent You reply directly.
Yuri
Note: If this post answers your question, please click the Correct Answer
button. Thank you!
Hi Yuri, it would be possible share the same information regarding iMX8QX + LPDDR4 line impedances?
Hello Yuri,
Now I am doing pcb design with iMX8MMini and I have got the same questions about layout LPDDR4 only for iMX8MMini. Could you send me these layout applications LPDDR4 for iMX8MMini?
Serg.
