Hello I am designing SoM board using i.MX8MM SoC
In my design I will use LBEE5HY1MW-230 as an combo wifi bt module.
In the EVK you have used SAI2 as an PCM interfaces. But in my design, it has to be SAI3.
Q1: Is it okey to use SAI3 in the module as PCM interface.
Q2: IC-LBEE5HY1MW-230 offers PCM and I2S interfaces what is the difference between these pins I don't understand
Q3: Can all SAIs be used as PCM
Hi EErdem
yes
PCM is general term, description can be found for example on
https://en.wikipedia.org/wiki/Pulse-code_modulation
yes
