Hi all
I want to know a support of Java ME in i.MX6.
My customer want to use i.MX6UL with Linux and end customer also want to use CLDC 1.1 of Java ME.
Connected Limited Device Configuration (CLDC) is as flow.
Connected Limited Device Configuration - Wikipedia, the free encyclopedia
I searched a i.MX Community and found following thread. But I couldn't figure out. So please let me know.
NXP ARM-based processor with Java SE support
Can i.MX6UL support CLDC 1.1 ?
Ko-hey
已解决! 转到解答。
Yes, you can use Java ME 8 for the i.MX6, please take a look at the following document:
This seems to be the only source I could find regarding i.MX6 and Java ME 8.
Can you please clarify your answer:
is Java ME 8 (Embedded) supported on the Cortex-A9 cores out-of-the-box? (like i.MX6 DualLite)
The linked documentation only talks about Cortex-M4 (which would be i.MX6 SoloX) as well as ARM9. As far as I know, ARM9 is not the same as the ARM Cortex-A9 used in the i.MX6, or is it?
Do you have any supporting documentation on how to get Java ME 8 up and running on an (Cortex-A9) i.MX6?
Your help is much appreciated.
Janek
