I am using iMX8MQ based custom board and I want to encrypt rootfs.
I have gone through the community link
I am facing the same as describe in above link. I am not able to create "/dev/caam-keygen" node.
I am working on kernel version 5.4.3 but I tried with kernel version 5.4.80 but still facing the same issue.
I am attaching kernel configuration for your reference.
Another thing I wanted to know that which device driver file is responsible to create "/dev/caam-keygen" node?
Thanks for reply.
I have follow the steps successfully and now I wanted to know that How to add support in yocto to create encrypted rootfs so that I can directly flash encrypted rootfs?
Hope for your quick response.
I am not able to open link which you have provided.
https://community.nxp.com/docs/DOC-342300
Can you give any alternative link for the same.
