Imx6 yocto photo display distortion
5,021件の閲覧回数
chenfeng2016
Hello
I met a problem on NXP imx6 yocot system, that is the photo display is distorted. The phenomenon is as follows photo files. please helps to analyze what causes it and how to solve it
Version: Linux 4.14.78_.0.0
ラベル(5)
6 返答(返信)
4,841件の閲覧回数
Rita_Wang
4,841件の閲覧回数
dioneva_k
What is the value of the vidargs variable in U-Boot?
Use the printenv command to find out
Seems to be low quality video settings
Example of the vidargs variable for iMX6 that I use:
video=mxcfb0:dev=ldb,1280x720M@60,if=RGB888,bpp=32 video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off fbmem=1024M
What is the value of bpp?
Dionevã M. Krolow
4,841件の閲覧回数
chenfeng2016
Hello. Dionevã Krolow
   Thanks for your help , according to your vidargs variable, the display work  right.
4,841件の閲覧回数
chenfeng2016
the env parameter  seted as below:
setenv mmcargs 'setenv bootargs ${bootargs} root=/dev/mmcblk3p2 rootwait rw video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24'
4,841件の閲覧回数
Rita_Wang
Which i.MX6 board are you using? Here is your ubuntu system can not work or the system on your i.MX6 board?
4,841件の閲覧回数
chenfeng2016
The board is imx6qp  with the yocto system,
by the way , it has the same phenomenon withe ubuntu system;
