Hello Team,
Ny customer has an inquiry about his new project:
My Nand Flash has 4 channels DQ0[0..7], DQ1[0..7], DQ2[0..7], DQ3[0..7],
What is the best way to connect it to the IMX8?
Wating for your kind feedback, many thanks.
Shai
the recommendation would be to stick with the memory controller pins to achieve performance, using controlled-by-gpio buffers I think that would increase complexity and flexibility.
Thank you, regards
The customer has stuck with the memory controller pins, please see their questions below:
Waiting for your kind feedback, Thanks a lot.
Shai
I think that the extra GPIOs would work but I haven't seen any performance over this action.
Shorting the 4-channel may not cause any problems as the different channels have their own control logic, right?
Why don't switch to a 8-bit NAND memory?
Thank you
