IMX6SX YOCTO
IMX6SX YOCTO
2548903578
Hi!
 I encountered a problem about imx6sx. I want yocto to generate uboot files about emmc. According to echo "UBOOT_CONFIG = \" emmc \"" >> conf / local.conf and MACHINE=<machine name> bitbake -c deploy u-boot-imx these two commands are still The uboot file of emmc cannot be generated. I did not find the corresponding .conf file for imx6sx under the directory imx-yocto-bsp/sources/meta-imx/meta-bsp/conf/machine. I just want to ask what should I do to generate the corresponding uboot image file of emmc.微信截图_20200904171145.png微信截图_20200904171228.png微信截图_20200904171415.png微信截图_20200904171543.png
weidong_sun
1. Use L5.4.24_2.1.0 ,  we didn't release document of L5.4.3_2.0.0.
2. Use standalone to compile u-boot and linux kernel.
In i.MX_Linux_User's_Guide.pdf,  see 4.5.11 How to build U-Boot and Kernel in standalone environment, please!
---Download u-boot source code
---Download linux-imx source code
---export toolchain through Yocto.
---install toolchain
3. compile u-boot
# make clean
# make mx6sxsabresd_emmc_defconfig
# make
It is easy to control some code or configurations for you in standalone operations.
Hope the information is helpful to you.
Have a nice day!
B.R,
weidong
weidong_sun
3. compile u-boot
# make clean
# make
Have a nice day!
B.R,
weidong
2548903578
Hi weidong_sun
Thank you very much for your reply, I have solved this problem through other methods. Thanks again!
