OS: Android 6.0
Kernel: 4.1.15
Our hardware function is use IN1R and IN1L using wm8962, the flow as following:
hdmi input audio -> DAC chip -> wm8962 in1R/L
Our hardware guy is confirm the DAC chip output is normal audio signal, but wm8962 still no sound in Android, how can I do? I know IN1 is difference on WM8962, it has to enabling PGA relative functions first, I already change as below:
dts:
sound {
compatible = "fsl,imx6q-sabresd-wm8962", "fsl,imx-audio-wm8962";
model = "wm8962-audio";
cpu-dai = <&ssi2>;
audio-codec = <&codec>;
asrc-controller = <&asrc>;
audio-routing =
"Headphone Jack", "HPOUTL",
"Headphone Jack", "HPOUTR",
"Ext Spk", "SPKOUTL",
"Ext Spk", "SPKOUTR",
"AMIC", "MICBIAS",
"IN1L", "AMIC",
"IN1R", "AMIC",
"DMIC", "MICBIAS",
"DMICDAT", "DMIC",
"CPU-Playback", "ASRC-Playback",
"Playback", "CPU-Playback",
"ASRC-Capture", "CPU-Capture",
"CPU-Capture", "Capture";
mux-int-port = <2>;
mux-ext-port = <3>;
hp-det-gpios = <&gpio4 10 1>;
HAL : config_wm8962.h
#define MIXER_WM8962_INPGAL_IN1L_SWITCH "INPGAL IN1L Switch"
#define MIXER_WM8962_MIXINL_PGA_SWITCH "MIXINL PGA Switch"
#define MIXER_WM8962_MIXINL_PGA_VOLUME "MIXINL PGA Volume"
#define MIXER_WM8962_INPGAR_IN1R_SWITCH "INPGAR IN1R Switch"
#define MIXER_WM8962_MIXINR_PGA_SWITCH "MIXINR PGA Switch"
#define MIXER_WM8962_MIXINR_PGA_VOLUME "MIXINR PGA Volume"
static struct route_setting mm_main_mic_input_wm8962[] = {
.ctl_name = MIXER_WM8962_CAPTURE_SWITCH,
.intval = 1,
.ctl_name = MIXER_WM8962_CAPTURE_VOLUME,
.intval = 63,
.ctl_name = MIXER_WM8962_DIGITAL_CAPTURE_VOLUME,
.intval = 127,
.ctl_name = MIXER_WM8962_INPGAL_IN1L_SWITCH,
.intval = 1,
.ctl_name = MIXER_WM8962_MIXINL_PGA_SWITCH,
.intval = 1,
.ctl_name = MIXER_WM8962_MIXINL_PGA_VOLUME,
.intval = 7,
.ctl_name = MIXER_WM8962_INPGAR_IN1R_SWITCH,
.intval = 1,
.ctl_name = MIXER_WM8962_MIXINR_PGA_SWITCH,
.intval = 1,
.ctl_name = MIXER_WM8962_MIXINR_PGA_VOLUME,
.intval = 7,
.ctl_name = NULL,
static struct route_setting mm_hs_mic_input_wm8962[] = {
.intval = 1,
.intval = 63,
.intval = 127,
.intval = 1,
.intval = 1,
.intval = 7,
.intval = 1,
.intval = 1,
.intval = 7,
.ctl_name = NULL,
But still no receive any sound when I enabling the microphone app in Android, what stuff I miss? Hope give me some comments, thank you so much!
Hi May
is it working in linux imx-test package audio test (folder ..test/mxc_sound_test)
imx-test
www.nxp.com/lgfiles/NMG/MAD/YOCTO/imx-test-5.7.tar.gz
one can debug this and add necessary settings in wm8962 driver using
Table 28-1. Stereo Codec SoC Driver Files attached Linux Manual.
