Hi, I am trying to H.264 encode the framebuffer in i.MX6Q. My requirement is to encode and stream the framebuffer. I am able to open /dev/fb0 and grab the frame. I understand from the H.26 encoder requirements that t operates only on YUV frames. I am trying color space conversion of RGB framebuffer using IPU and then encoding using the VPU. But all these operations takes more than 100ms which I am not able to afford. Could you please suggest me a better way to do this? Is there a way I can configure /dev/fb0 for YUV and H.264 encoder can directly operate on framebuffer memory? Is there any samples available?
Hi Igor,
Thanks for the response.
I am using the following encode and decode example code.
https://github.com/Freescale/libimxvpuapi/blob/master/example/encode-example.c
https://github.com/Freescale/libimxvpuapi/blob/master/example/decode-example.c
I am trying to H264 encode a single frame (1920 * 1080 in I420 format). Encoding is succeeded using the encode example (I have updated frame width and height as 1920* 1080 in the example code). But while decoding using decode example I get following error and it is not producing decoded image file. What could be the problem here? Is it not possible to decode a single frame.
[INFO] bitstreamMode 1, chromaInterleave 0, mapType 0, tiled2LinearEnable 0
encoded input frame: frame id: 0x64 size: 320710 byte
initial info: size: 1920x1088 pixel rate: 4294967295/4294967295 min num required framebuffers: 8 interlacing: 0 framebuffer alignment: 1
calculated sizes: frame width&height: 1920x1088 Y stride: 1920 CbCr stride: 960 Y size: 2088960 CbCr size: 522240 MvCol size: 522240 total size: 3655681
draining decoder
VPU reports EOS; no more decoded frames available
Thanks & Regards
Anoop
Hi Anoop
libimxvpuapi is community api, please post its issues on
meta-fsl-arm mailing list, so that someone familiar with it could try to assist you.
https://lists.yoctoproject.org/listinfo/meta-freescale
also one can look at vpu examples in unit tests
imx-test
www.nxp.com/lgfiles/NMG/MAD/YOCTO/imx-test-5.7.tar.gz
Hi Igor,
Thanks for your support.
I tried out the VPU H.264 unit test. I am seeing ~30fps for encoding 1920*1080 frame. But for decoding it is showing fps as ~6fps. It takes about 162ms for decoding a single frame. That is way too slow. What could be the issue?
root@imx6qsabreauto:/unit_tests# ./mxc_vpu_test.out -E "-i /home/root/converted.yuv -f 2 -a 25 -o te...
[INFO] VPU test program built on Jun 19 2017 11:13:06
[INFO] Product Info: i.MX6Q/D/S
[INFO] VPU firmware version: 3.1.1_r46072
[INFO] VPU library version: 5.4.35
[INFO] Format: STD_AVC
[INFO] AVC
[INFO] Input file "/home/root/converted.yuv" opened.
[INFO] Output file "test1.h264" opened.
[INFO] Capture/Encode fps will be 25
[INFO] ringBufferEnable 0, chromaInterleave 1, mapType 0, linear2TiledEnable 0
[INFO] Finished encoding: 1 frames
[INFO] enc fps = 44.92
[INFO] total fps= 30.77
Hi Anoop
please try Demo Images on i.MX6Q Sabre AI board
Hi Igor,
Thanks for the quick response!. I have referred mxc_vpu_test application. I would like to know if /dev/fb0 can be configured for YUV color space and I can use this framebuffer directly for H.264 encoding.
Thanks & Regards
Anoop
Hi Anoop
data for encoding may be feed also from framebuffer, one can use
(if necessary) color conversion using examples on
https://community.freescale.com/docs/DOC-94961
Hi Igor,
Thanks for the examples.
I tried to change the VPU clock frequency to MX6_VPU_352M in menuconfig to improve performance. But after setting this the encoder performance is lowered. Is there any other configuration that I need to do for changing VPU clock?
Thanks & Regards
Anoop
Hi Anoop
please check VDD_SOC voltage for 352MHz operation
described in Table 6. Operating Ranges i.MX6DQ Reference Manual
http://cache.nxp.com/files/soft_dev_tools/doc/support_info/iMX6DQPRM.pdf
Hi Anoop
please check examples in unit tests (..test/mxc_vpu_test)
imx-test
