yes, you are right Gavin,
i do have same issue and solved by adding caps before mfw_ipucsc, but i have one more requirement is
to change the mfw_ipucsc output dynamically, i am using the gstreamer call " gst_element_link_filtered ()" and working file initially.
but i if try to change caps (after pausing pipeline) and again try to link, not working. can anybody help me ?
the actual requirement is _______ the output of scale can be variable
videosrc(1080p awlays) ---> scale -----> vpuenc
regards
nagendra
