For example, to change MX6Q_PAD_GPIO_1 configuration from pin 137 (MX6Q_PAD_GPIO_1):0x17059 to pin 137 (MX6Q_PAD_GPIO_1):0x17058, can anybody give a example how to change it?
Yan
Solved! Go to Solution.
Hi Yan Gao,
You can not change the i.MX6 PIN or configuration dynamically. Once you have configured the PIN, you can not to change the configuration in application.
Rita
Hi Yan Gao,
Rita
