How many frequency tolerance in ppm of i.MX8M Mini 24MHz crtstal?
981件の閲覧回数
m_c
Senior Contributor I
881件の閲覧回数
gusarambula
Hello m.c,
Usually the tolerance is given by the protocols you would be using. If you are using Ethernet, the recommended tolerance is usually +/- 50ppm and other protocols require less precision.
The i.MX8M Mini documentation does not seem to cover it, let me double check. I’ll let you know when I have more information.
882件の閲覧回数
gusarambula
Hello m.c,
