GPIO CONFIGURATION IN IMX8M MINI EVK
VinithNama
      How can I configure a gpio pin in j1003 connector,I need to set SAI5_RXD3 pin and it need to appear in the cat /sys/gpio
nxf63675
Hi Vinith,
You can use the config tool that we have to configure the GPIO's, it simple and generate the code of the device your are using automatically, please take a look:
https://www.nxp.com/design/designs/config-tools-for-i-mx-applications-processors:CONFIG-TOOLS-IMX
Hope this helps you.
Israel.
VinithNama
     We can use MCU XPRESSO IDE for developing the applications for the imx8m mini evk IDE ,can you share the information about using the ide and building programs and sample demo applications how to run from ide to target board
