Dear, Yuri
Even the newest Script Aid does not have setting for DDR3-1866.
When choosing DDR3-1066 using this script, which value is used from memory the data sheet?
* The memory to be used is MT41K256M16TW-107.
or
Fukutomi
Solved! Go to Solution.
Use memory Datasheet parameters for DDR3L-1066.
Yuri
Note: If this post answers your question, please click the Correct Answer
button. Thank you!
Yuri
button. Thank you!
Fukutomi
