Hi All ,
I follow this link on Freescale Yocto Training but fail on : bitbake fsl-image-gui.
The error message is :
WARNING: Failed to fetch URL git://gitorious.org/qt-in-use/qt-in-industrial-embedded.git, attempting MIRRORS if available
ERROR: Fetcher failure: Fetch command failed with exit code 128, output:
Cloning into bare repository '/home/rick/2fsl-community-bsp/downloads//git2/gitorious.org.qt-in-use.qt-in-industrial-embedded.git'...
fatal: The remote end hung up unexpectedly
ERROR: Function failed: Fetcher failure for URL: 'git://gitorious.org/qt-in-use/qt-in-industrial-embedded.git'. Unable to fetch URL from any source.
ERROR: Logfile of failure stored in: /home/rick/2fsl-community-bsp/build/tmp/work/cortexa9hf-vfp-neon-poky-linux-gnueabi/qt-in-industrial-embedded-smarthome/0.0+gitrAUTOINC+4b10cbfd32-r3/temp/log.do_fetch.20091
ERROR: Task 2564 (/home/rick/2fsl-community-bsp/sources/meta-fsl-demos/recipes-qt/qt-in-use/qt-in-industrial-embedded-smarthome_git.bb, do_fetch) failed with exit code '1'
NOTE: Tasks Summary: Attempted 3178 tasks of which 287 didn't need to be rerun and 1 failed.
Waiting for 0 running tasks to finish:
Summary: 1 task failed:
Summary: There were 12 WARNING messages shown.
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
I try this manually :
git clone git://gitorious.org/qt-in-use/qt-in-industrial-embedded.git
and I got : fatal . remote host close unexpectedly
I think Yocto is trying to clone qt-in-industrial-embedded.git but unable to complete.
Anyone know how to fix it ?
Ricky
Please use the recent Linux BSP for the i.MX6, which may be found on the next Summary Page :
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=IMX6_SW
Yuri
Hi Yuri ,
Thanks for your quick response.
Last week I follow the same YOCTO instructions and I did not get this error message. I went to that directory and found this :
rick@kingstonV120:~/fsl-community-bsp/downloads/git2$ ls -alrt gitorious*
-rw-rw-r-- 1 rick rick 0 Mar 6 03:52 gitorious.org.qt-in-use.qt-in-industrial-embedded.git.done
gitorious.org.qt-in-use.qt-in-industrial-embedded.git:
total 52
drwxrwxr-x 4 rick rick 4096 Mar 6 03:52 refs
drwxrwxr-x 2 rick rick 4096 Mar 6 03:52 info
drwxrwxr-x 2 rick rick 4096 Mar 6 03:52 hooks
-rw-rw-r-- 1 rick rick 73 Mar 6 03:52 description
drwxrwxr-x 2 rick rick 4096 Mar 6 03:52 branches
drwxrwxr-x 4 rick rick 4096 Mar 6 03:52 objects
-rw-rw-r-- 1 rick rick 190 Mar 6 03:52 config
-rw-rw-r-- 1 rick rick 85 Mar 6 03:52 packed-refs
-rw-rw-r-- 1 rick rick 23 Mar 6 03:52 HEAD
drwxrwxr-x 7 rick rick 4096 Mar 6 03:52 .
drwxrwxr-x 52 rick rick 12288 Mar 6 09:23 ..
In the directory downloads , there is a git2 directory which store the "DONE" file and the clone of "gitorious.org.qt-in-use.qt-in-industrial-embedded.git".
I copy the DONE file and the whole clone directory to my new run directory and run "bitbake fsl-image-gui " again and the Yocto takes it and continue to run.
I think sometime this week QT must done something to prevent user to clone ????
As I mentioned before , this command return ERROR : git clone git://gitorious.org/qt-in-use/qt-in-industrial-embedded.git
Do you know anyone in QT to confirm this ?
Thanks for your reply.
Rick
Hi Rick,
I'm facing the same issue but I'm behind a proxy that don't like git.
Using HTTPS it seems better
git clone https://gitorious.org/qt-in-use/qt-in-industrial-embedded.git
Cloning into 'qt-in-industrial-embedded'...
remote: Counting objects: 211, done.
Checking connectivity... done.
I change it in the recipe meta-fsl-demos/recipes-qt/qt-in-use/qt-in-industrial-embedded-common.inc :
SRC_URI = "git://gitorious.org/qt-in-use/qt-in-industrial-embedded.git;protocol=https \
Olivier.
