The problem is in qt4-imx-support.inc file in meta-fsl-arm/recipies-qt/qt:
FILESEXTRAPATHS_prepend := "${THISDIR}/qt4:"
python __anonymous () {
families = ['mx5', 'mx6']
cur_families = (d.getVar('SOC_FAMILY', True) or '').split(':')
if any(map(lambda x: x in cur_families,
families)):
d.appendVarFlag('do_configure', 'depends', ' virtual/kernel:do_shared_workdir')
SRC_URI_append_mx5 += "file://0001-Add-support-for-i.MX-codecs-to-phonon.patch"
SRC_URI_append_mx6 += " \
file://0001-Add-support-for-i.MX-codecs-to-phonon.patch \
file://0002-i.MX-video-renderer-Allow-v4l-device-from-environmen.patch \
file://0003-i.MX6-force-egl-visual-ID-33.patch \
DEPENDS_append_mx5 = " virtual/kernel virtual/libgles2"
QT_GLFLAGS_mx5 = "-opengl es2 -openvg"
QT_CONFIG_FLAGS_append_mx5 = " -I${STAGING_KERNEL_DIR}/include/"
DEPENDS_append_mx6 = " virtual/kernel virtual/libgles2"
QT_GLFLAGS_mx6 = "-opengl es2 -openvg"
QT_CONFIG_FLAGS_append_mx6 = " -I${STAGING_KERNEL_DIR}/include/uapi \
-I${STAGING_KERNEL_DIR}/include/ \
-DLINUX=1 -DEGL_API_FB=1 \
-DQT_QPA_EXPERIMENTAL_TOUCHEVENT=1"
I comment this lines ¿is correct?.
Thanks.
