I have recently acquired a i.MX 8M Nano EVK board and can't seem to start the U-boot prompt. During booting I press any key (on the keyboard) as instructed here, but the operating system starts anyway.
I have tried both the Android system preinstalled on eMMC and the Linux system installed on SDcard (imx-image-full-imx8mnevk.wic found here).
Attached is the Serial Debug log.
Thank you un advance.
已解决! 转到解答。
hi i saw your boot logs :
Fastboot: Normal
Normal Boot
Hit any key to stop autoboot: 0
the delay may be set to 0 second , thats why your have no time to press any key to enter u-boot command lah
solution:
pleaae goto your u-boot command and environment to edit ,
bootdelay = 10
it will delay 10 seconds to let your press any key to enter u-boot .
please try it out and let me know how it is work for u or not
thanks all
what imx8mn evk board do you have? lpddr4 or ddr4? nxp board or customized board?
"During booting I press any key (on the keyboard) as instructed here, but the operating system starts anyway."
>but refer to you logfile, your kernel doesn't start, so when you press any key, your board stuck as the logfile shows?
Fastboot: Normal
Normal Boot
solution:
bootdelay = 10
thanks all
