Does vpuenc_h264 uses hardware encoding? how?
2,516件の閲覧回数
sagarmane
I'm using i.MX8M Plus EVK board. Does vpuenc_h264 uses hardware encoding in below example of gstreamer?
#gst-launch-1.0 videotestsrc num-buffers=300 ! video/x-raw,width=1920,height=1080,format=YUY2 ! queue ! vpuenc_h264 ! filesink location=output.h264
タグ(1)
2,502件の閲覧回数
joanxie
this uses HW(vpu) encoder
3 返答(返信)
2,508件の閲覧回数
sagarmane
Hi @joanxie ,
Thanks for your response.
Yes this does work. My question was does vpuenc_h264 uses actual hardware available in board for encoding? or it is software encoding with gstreamer.
2,503件の閲覧回数
joanxie
2,511件の閲覧回数
joanxie
imx8mp should support this, you can try this, if you have any issue, pls tell me
