Hi Ko-hey
erratum did not affect MCIMX6Q-SDB, as it affects boards designed in such way
and using crystals which picks-up noise during crystal start up. In particular Chip Errata document
describes it as follows:
"If the noise contains frequency components higher than approximately 500 kHz"
In general this depends on board layout and design.
Hello Igor
How to use scope to measure "the crystal has higher than 500khz noise on 32.768khz crystal"?
Sincerely
Max
Hi Igor
Thank you for quick reply.
I understand.
Ko-hey
