I would like to know what options are available for source level debugging of U-boot for the iMX6 processor (Quad or Solo).
I have a custom board using iMX6S and the design for this board is based on the Sabre SD reference board which uses iMX6Q.
To begin with, I would like to setup the environment to debug U-boot for the Sabre SD board.
I can then use this as the basis for setting up the debug environment for my custom board.
Here is my current setup:
- Reference board used: Sabre SD board - MCIMX6Q SDB
- Kernel version: LTIB Linux 3.0.35
- U-boot version: 2009.08
I have a bootable SD card that has all the binaries (U-boot, kernel and rootfs) and I can bring up the Sabre board with these binaries.
So now, I would like to modify U-boot for my custom board and hence would like to have a debugging environment that allows for single stepping.
Has anyone tried using J-link? If yes, what was the setup (use Eclipse for building U-boot and then use JTAG for debugging)?
Any pointers here will be very helpful.
MG.
Hi M G
I think subject well described on various links below, please
look at them
ARM DS-5 Quick Start (i.MX6) - BlueWiki
Getting J-Link working with i.MX6Q - J-Link/Flasher related - SEGGER Forum
Problems debugging I.MX6 with J-Link and GDB-Server - J-Link/Flasher related - SEGGER Forum
AN4553 Using Open Source Debugging Tools for Linux on i.MX Processors
chip
Thanks for the pointers.
I had looked at some of these options but not all.
I’ll set up something in the next few weeks.
