Cannot flash .wic image using UUU tool
karthicknarayanan
I am trying to flash a .wic image to imx8mp using UUU tool in linux. The USB is detected correctly and I am already using sudo but still it shows the following error.
3:1 1/ 0 [Failure open usb device,Try sudo uuu ]
I am using following to command to flash the image
sudo uuu -b emmc_all imx-boot-imx8mp-lpddr4-evk-sd.bin-flash_evk imx-image-core-imx8mp-lpddr4-evk.wic.zst*
jimmychan
Have you try like this?
uuu -b emmc_all imx-image-core-imx8mp-lpddr4-evk.wic.zst
karthicknarayanan
Yes I have tried this command , it was not working.
jimmychan
Are you using i.MX8MP EVK?
Which version of ubuntu are you using? Please try to update the libusb.
Have you try to program the demo image using uuu.auto?
jimmychan
You could try newer release of uuu
https://github.com/nxp-imx/mfgtools/releases
Or you could try to use the Windows version (uuu.exe)
karthicknarayanan
Thanks for the reply jimmy chan
I am getting same issue again after trying it with newer version UUU and we need to work it with linux
