In Table 5-10 of iMX7D RM, there is external signal CCM_ENET3_REF_CLK with following mux-mode:
Check GPIO1_IO01 pad muxmode, there is:
ALT2_CCM_ENET_REF_CLK3 — Select mux mode: ALT2 mux port: ENET_REF_CLK3 of instance: CCM
and GPIO1_IO09 pad muxmode:
ALT2_CCM_ENET_PHY_REF_CLK — Select mux mode: ALT2 mux port: ENET_PHY_REF_CLK of instance: CCM
and I2C2_SDA pad muxmode:
ALT4_CCM_ENET_PHY_REF_CLK — Select mux mode: ALT4 mux port: ENET_PHY_REF_CLK of instance: CCM
As my understanding, three different signal names represent the same signal, coresponding to IMX7D_ENET_PHY_REF_ROOT_DIV in DTS file. Is it right?
Cheng Shi
Solved! Go to Solution.
With test:
CCM_ENET3_REF_CLK = CCM_ENET_REF_CLK3 = CCM_ENET_PHY_REF_CLK;
Please update document in later version.
With test:
documentation...
I just found that CCM_ENET_PHY_REF_CLK could be found at different places in a reference manual (my use case: iMX8plus reference), if the pdf version of the source document at NXP offices would not break this search term into two snippets. A screenshot says more than 1000 words:
This pdf exporter behaviour (should keep texts within table cells as concise searchable) is a true catastrophe, aggravated by the partially unclear or in detail too sparse documentation details. But even when the cursor selection of a word is highlighted cleanly within a cell, a linefeed character is part of this selection, and hence a search across the document may not find the search term (dependent on pdf viewer used).
I can only repeat: please update the documentation, as the thread starter wrote, but now especially targeted on using another pdf exporter!
Anyway, I found AN 14149, which is helpful.
