I am using 8M Mini on a design and we need to support carplay on the same.
Based on 8M Mini datasheet, there is no inbuilt codec for encoding and decoding.
MCIMX6Q-Smart device board has WM8962 and MCIMX8QXP-CPU MEK Platform design has WM8960 as codecs. Which Codec IC would you recommend to be used with 8M Mini to support carplay?
Hi @M8!
Thank you for contacting NXP Support!
For carplay, I recommend using iMX8 or iMX8X because are parts compatible with carplay, the iMX8MM doesn't have automotive certification.
The drivers are implemented on iMX8 and iMX8X I recommend moving for those options.
For the codec, I recommend "WM8960".
Best Regards!
Chavira
