Android on iMX233
Android on iMX233
1,194 次查看
kpoojari7
Hi everyone,
I am trying to port Android onto iMX23evk. I tried converting the linux BSP provided along with the board to Android Kernel by adding the essential components to it and I have compiled Android Froyo in emulator mode and I have performed chroot to android file system on the board.  I have ended with the following display. I think this is due to mismatch in the screen resolution between emulator and the actual screen on board. As I am new to this, I am not able to fix it. Please help me to correct it.
标签 (4)
标记 (1)
835 次查看
igorpadykov
Hi Venkatesh
for LCD testing and verification one can try to reuse i.MX28 OBDS lcd test
IMX_OBDS : On-Board Diagnostic Suit for the i.MX28.
Also useful some i.MX23 porting hints on below link
Porting Linux to a new board — Christian's Blog
835 次查看
kpoojari7
Hi igorpadykov,
Thank you very much for your reply.
Actually I have no problem with the LCD as the Linux boot image is displayed clearly.
After I perform chroot to android file system I am getting this problem (as seen in the above attached image).
I wanted to know how to set the screen parameters from the android end.
