AUDMUX internal to internal port connectivity
1,478件の閲覧回数
saurabh206
Senior Contributor III
I want to set AUDMUX internal to internal port connectivity.
What changes required in imx_audmux_config.
I have gone through the AUDMUX IMX6DQRM :Chapter 16.
Saurabh
タグ(1)
1,155件の閲覧回数
saurabh206
Hi Jimmy
This issue is already fixed.
Now AUDMUX internal to internal port connectivity is working perfectly.
Saurabh
5 返答(返信)
1,154件の閲覧回数
宗標廖
Hello, Saurabh
Could you tell me your workaround?
Thank you very much!
ZongbiaoLiao
1,154件の閲覧回数
saurabh206
ZongbiaoLiao
I need to do following modification.
- Continues clock generation for SSI.
- Correct imx_audmux_config for Internal mode
- Register Dummy recording driver
And used ALSA aplay/arecord command to start playback and capture.
Saurabh
1,155件の閲覧回数
saurabh206
Is there any update?
I have implemented but I am getting silence data.
1,155件の閲覧回数
jimmychan
would you show more details about what you want to do?
and what you have done at this moment?
what BSP are you using?
1,156件の閲覧回数
saurabh206
Hi Jimmy
Saurabh
