command adb devices
its not recogising the imx8m mini evk board
Hi @Ruban1,
Would you please share the log of the error?
From your description, you may want to first check if you enabled the USB developer option within your Android BSP.
This document might be helpful:
Cheers
Hi @Ruban1
Cheers
the in command window i typed
adb devices
it doesnot show anything.. its empty. As if its not connected to host PC
Hi @Ruban1 ,
Please make sure that you are executing adb devices within the same folder as adb.exe. Just tested this on an i.MX 8M Nano EVK with success; you should see something similar:
C:\Android\platform-tools_r31.0.2-windows\platform-tools>adb devices
* daemon not running; starting now at tcp:5037
* daemon started successfully
List of devices attached
1e0b3a0a5c85f0d5 device
I am using the Android SDK Platform Tools, btw.
Hope this helps!
Good!
i am using ubuntu 20.04 .. cant u provide me details regarding ubuntu 20.04. not windows
Just tested this on my Ubuntu 20.04 laptop. Hope it helps.
1. Install adb
ruben@ruben-HP-ZBook-15-G3:~$ sudo apt install adb
2. Connect your i.MX EVK using an USB cable, make sure to not use the debug UART.
3. Start adb
ruben@ruben-HP-ZBook-15-G3:~/Pictures$ sudo adb start-server
[sudo] password for ruben:
4. Make sure to have your EVK listed
ruben@ruben-HP-ZBook-15-G3:~/Pictures$ adb devices -l
1e0b3a0a5c85f0d5 device usb:1-4 product:evk_8mn model:EVK_8MN device:evk_8mn transport_id:1
4. In my case, I transferred a picture from my laptop to the EVK, just to test:
ruben@ruben-HP-ZBook-15-G3:~/Pictures$ adb push apalis.jpg /storage/emulated/0/DCIM
apalis.jpg: 1 file pushed. 12.0 MB/s (133704 bytes in 0.011s)
5. Finish. Open your gallery at Android and you should see the the file.
ruben@ruben-HP-ZBook-15-G3:~/Pictures$ adb kill-server
6. Optional. It may possible that you need to enable adb as root user
ruben@ruben-HP-ZBook-15-G3:~/Pictures$ adb root
