i.MX27 ADS Compiling Linux Kernel Mainline
This steps are basically the same used to boot Linux mainline on i.MX 31 ADS, just replacing Network Driver cs89x0 by i.MX 27 internal FEC.
Download Linux kernel 2.6.30:
$ wget -c http://www.kernel.org/pub/linux/kernel/v2.6/linux-2.6.30.tar.bz2
Extract this:
$ tar jxvf linux-2.6.30.tar.bz2
Export CROSS_COMPILE environmet:
$ export PATH="$PATH:/opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/"
$ export CROSS_COMPILE=arm-none-linux-gnueabi-
Unselect all no essentials features:
$ make ARCH=arm allnoconfig
Start the configuration menu:
$ make ARCH=arm menuconfig
Change/Select the kernel options below.
Select the MXC/iMX platform and iMX27ADS board:
System Type ->
            ARM system type -> (X) Freescale MXC/iMX-based
            Freescale MXC Implementations  ->
                           MXC/iMX Base Type -> (X) MX2-based
                           MX2 Options  -> [*] Support MX27ADS platforms (NEW)
Select ARM EABI standard to compile the kernel:
Kernel Features  --->
          [*] Use the ARM EABI to compile the kernel
Add support to Linux Binary Format ELF:
Userspace binary formats ->
             [*] Kernel support for ELF binaries
Add support to Network (TCP/IP):
[*] Networking support  ->
         Networking options  ->
                          [*] Packet socket
                          [*] Unix domain sockets
                          [*] PF_KEY sockets
                          [*] TCP/IP networking
                                   [*] IP: kernel level autoconfiguration
                                   [*]     IP: DHCP support
Select network driver (FEC), serial driver and unselect VGA console:
Device Drivers  ->
              [*] Network device support  --->
                                      [*]   Ethernet (10 or 100Mbit)  --->
                                             [*]   FEC ethernet controller (of ColdFire CPUs)
              Character devices  ->
                             Serial drivers  --->
                                      [*] IMX serial port support
                                      [*]   Console on IMX serial port
              Graphics support  ->
                             Console display driver support  --->
                                        [ ] VGA text console
Add support to NFS and support to use it as root file system:
File systems  ->
                          [*] Network File Systems (NEW)  ->
                                   [*]   NFS client support
                                   [*]     Root file system on NFS
Compile the kernel:
$ make ARCH=arm
Copy the created zImage to tftp directory:
$ cp arch/arm/boot/zImage /tftpboot/
Configure your RedBoot to boots with this kernel:
load -r -b 0x100000 /tftpboot/zImage
exec -b 0x100000 -l 0x200000 -c "noinitrd console=ttymxc0,115200 root=/dev/nfs nfsroot=10.29.240.191:/tftpboot/rootfs ip=dhcp"
Change the default network device on RedBoot to internal FEC:
Default network device: mxc_fec
Connect the network cable on FEC connector (connector T3).
Notes: We are using rootfs from LTIB then select to get parameters from DHCP:
"Target System Configuration"
Options  --->
              [*] start networking
                     Network setup  --->
                           [*]   get network parameters using dhcp
%3CLINGO-SUB%20id%3D%22lingo-sub-1102666%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX27%20ADS%20Compiling%20Linux%20Kernel%20Mainline%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1102666%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThis%20steps%20are%20basically%20the%20same%20used%20to%20boot%20Linux%20mainline%20on%20i.MX%2031%20ADS%2C%20just%20replacing%20Network%20Driver%20cs89x0%20by%20i.MX%2027%20internal%20FEC.%3C%2FP%3E%3CP%3EDownload%20Linux%20kernel%202.6.30%3A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%24%20wget%20-c%20%3CA%20class%3D%22free%20external%22%20href%3D%22http%3A%2F%2Fwww.kernel.org%2Fpub%2Flinux%2Fkernel%2Fv2.6%2Flinux-2.6.30.tar.bz2%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.kernel.org%2Fpub%2Flinux%2Fkernel%2Fv2.6%2Flinux-2.6.30.tar.bz2%3C%2FA%3E%20%3C%2FPRE%3E%3CP%3EExtract%20this%3A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%24%20tar%20jxvf%20linux-2.6.30.tar.bz2%20%3C%2FPRE%3E%3CP%3EExport%20CROSS_COMPILE%20environmet%3A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%24%20export%20PATH%3D%22%24PATH%3A%2Fopt%2Ffreescale%2Fusr%2Flocal%2Fgcc-4.1.2-glibc-2.5-nptl-3%2Farm-none-linux-gnueabi%2Fbin%2F%22%20%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%24%20export%20CROSS_COMPILE%3Darm-none-linux-gnueabi-%20%3C%2FPRE%3E%3CP%3EUnselect%20all%20no%20essentials%20features%3A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%24%20make%20ARCH%3Darm%20allnoconfig%20%3C%2FPRE%3E%3CP%3EStart%20the%20configuration%20menu%3A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%24%20make%20ARCH%3Darm%20menuconfig%20%3C%2FPRE%3E%3CP%3EChange%2FSelect%20the%20kernel%20options%20below.%3C%2FP%3E%3CP%3ESelect%20the%20MXC%2FiMX%20platform%20and%20iMX27ADS%20board%3A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3ESystem%20Type%20-%26gt%3B%20%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ARM%20system%20type%20-%26gt%3B%20(X)%20Freescale%20MXC%2FiMX-based%20%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Freescale%20MXC%20Implementations%26nbsp%3B%20-%26gt%3B%20%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MXC%2FiMX%20Base%20Type%20-%26gt%3B%20(X)%20MX2-based%20%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX2%20Options%26nbsp%3B%20-%26gt%3B%20%5B*%5D%20Support%20MX27ADS%20platforms%20(NEW)%0A%3C%2FPRE%3E%3CP%3ESelect%20ARM%20EABI%20standard%20to%20compile%20the%20kernel%3A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3EKernel%20Features%26nbsp%3B%20---%26gt%3B%20%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B*%5D%20Use%20the%20ARM%20EABI%20to%20compile%20the%20kernel%0A%3C%2FPRE%3E%3CP%3EAdd%20support%20to%20Linux%20Binary%20Format%20ELF%3A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3EUserspace%20binary%20formats%20-%26gt%3B%20%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B*%5D%20Kernel%20support%20for%20ELF%20binaries%0A%3C%2FPRE%3E%3CP%3EAdd%20support%20to%20Network%20(TCP%2FIP)%3A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%5B*%5D%20Networking%20support%26nbsp%3B%20-%26gt%3B%20%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Networking%20options%26nbsp%3B%20-%26gt%3B%20%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B*%5D%20Packet%20socket%20%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B*%5D%20Unix%20domain%20sockets%20%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B*%5D%20PF_KEY%20sockets%20%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B*%5D%20TCP%2FIP%20networking%20%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B*%5D%20IP%3A%20kernel%20level%20autoconfiguration%20%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B*%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20IP%3A%20DHCP%20support%0A%3C%2FPRE%3E%3CP%3ESelect%20network%20driver%20(FEC)%2C%20serial%20driver%20and%20unselect%20VGA%20console%3A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3EDevice%20Drivers%26nbsp%3B%20-%26gt%3B%20%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B*%5D%20Network%20device%20support%26nbsp%3B%20---%26gt%3B%20%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B*%5D%26nbsp%3B%26nbsp%3B%20Ethernet%20(10%20or%20100Mbit)%26nbsp%3B%20---%26gt%3B%20%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B*%5D%26nbsp%3B%26nbsp%3B%20FEC%20ethernet%20controller%20(of%20ColdFire%20CPUs)%0A%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Character%20devices%26nbsp%3B%20-%26gt%3B%20%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Serial%20drivers%26nbsp%3B%20---%26gt%3B%20%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B*%5D%20IMX%20serial%20port%20support%20%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B*%5D%26nbsp%3B%26nbsp%3B%20Console%20on%20IMX%20serial%20port%0A%3C%2FPRE%3E%3CPRE%20class%3D%22jive-pre%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Graphics%20support%26nbsp%3B%20-%26gt%3B%20%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Console%20display%20driver%20support%26nbsp%3B%20---%26gt%3B%20%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B%20%5D%20VGA%20text%20console%0A%3C%2FPRE%3E%3CP%3EAdd%20support%20to%20NFS%20and%20support%20to%20use%20it%20as%20root%20%3CA%20href%3D%22http%3A%2F%2Fwww.imxdev.org%2Fwiki%2Findex.php%3Ftitle%3DIMX27ADS_Compiling_Linux_kernel_mainline%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20style%3D%22text-decoration%3A%20underline%3B%22%20title%3D%22Powered%20by%20Text-Enhance%22%20target%3D%22_blank%22%3Efile%3C%2FA%3E%20system%3A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3EFile%20systems%26nbsp%3B%20-%26gt%3B%20%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B*%5D%20Network%20File%20Systems%20(NEW)%26nbsp%3B%20-%26gt%3B%20%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B*%5D%26nbsp%3B%26nbsp%3B%20NFS%20client%20support%20%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B*%5D%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Root%20file%20system%20on%20NFS%0A%3C%2FPRE%3E%3CP%3ECompile%20the%20kernel%3A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%24%20make%20ARCH%3Darm%20%3C%2FPRE%3E%3CP%3ECopy%20the%20created%20zImage%20to%20tftp%20directory%3A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%24%20cp%20arch%2Farm%2Fboot%2FzImage%20%2Ftftpboot%2F%20%3C%2FPRE%3E%3CP%3EConfigure%20your%20RedBoot%20to%20boots%20with%20this%20kernel%3A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3Eload%20-r%20-b%200x100000%20%2Ftftpboot%2FzImage%20%0Aexec%20-b%200x100000%20-l%200x200000%20-c%20%22noinitrd%20console%3Dttymxc0%2C115200%20root%3D%2Fdev%2Fnfs%20nfsroot%3D10.29.240.191%3A%2Ftftpboot%2Frootfs%20ip%3Ddhcp%22%0A%3C%2FPRE%3E%3CP%3EChange%20the%20default%20network%20device%20on%20RedBoot%20to%20internal%20FEC%3A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3EDefault%20network%20device%3A%20mxc_fec%20%3C%2FPRE%3E%3CP%3EConnect%20the%20network%20cable%20on%20FEC%20connector%20(connector%20T3).%3C%2FP%3E%3CP%3ENotes%3A%20We%20are%20using%20rootfs%20from%20LTIB%20then%20select%20to%20get%20parameters%20from%20DHCP%3A%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%22Target%20System%20Configuration%22%20%0AOptions%26nbsp%3B%20---%26gt%3B%20%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B*%5D%20start%20networking%20%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Network%20setup%26nbsp%3B%20---%26gt%3B%20%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B*%5D%26nbsp%3B%26nbsp%3B%20get%20network%20parameters%20using%20dhcp%0A%3C%2FPRE%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1102666%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX2x%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
No ratings
Version history
Last update:
‎09-10-2020 01:46 AM
Updated by:
