Patch for sii902x hdmi driver via IPU
The default BSP release supports sii902x hdmi card via LCDIF in i.MX6 Solo, but doesn't support it via IPU display interface in i.MX6 Dual/Quad/Plus. The patch provides support for the Sii902x HDMI video driver for i.MX6 Dual/Quad/Plus.
Useful documents:
MCIMXHDMICARD: Schematic for sii902x hdmi card
MCIMX6Q-SMART DEVICE PLATFORM: Schematic for i.MX6 Quad Sabre SDP
Software version:
Linux 3.14.52_1.1.0-ga
Verified platform:
imx6q-sabresd
imx6qp-sabresd
Patch:
0001-video-mxc-sii902x-add-sii902x-hdmi-card-driver.patch
0002-arch-arm-boot-dts-add-sii902x-hdmi-card-devicetree-n.patch
Features:
  1. Support video mode setup via uboot command;
  2. Support video mode setup via device tree;
  3. Supprt HDMI hot-plug;
  4. Support many video modes and a dynamic switching between them;
Notes:
The default settings( don't add "video=" to bootcmd) are as follows:
------------ /sys/class/graphics/fb0
DISP4 BG - DI1
U:1024x768p-60
ldb
2-layer-fb-bg
------------ /sys/class/graphics/fb1
DISP4 FG
overlay
2-layer-fb-fg
------------ /sys/class/graphics/fb2
DISP3 BG - DI1
U:1920x1080p-60
hdmi
2-layer-fb-bg
------------ /sys/class/graphics/fb3
DISP3 FG
overlay
2-layer-fb-fg
------------ /sys/class/graphics/fb4
DISP3 BG
sii902x_hdmi
1-layer-fb
------------ /sys/class/graphics/fb5
DISP4 BG
If you want sii902x_hdmi to be fb0, you can add following arguments to bootcmd:
video=mxcfb0:dev=sii902x_hdmi,1920x1080M@60,if=RGB24 video=mxcfb1:off video=mxcfb2:off video=mxcfb2:off consoleblank=0
Risks:
Sometimes the sii902x will fail to read hdmi edid information, and the modelist of this framebuffer will be NULL. At this time, the driver will setup a default video mode which has been tuned  on imx6q-sabresd and imx6qp-sabresd. The default video mode is as follows:
/* 1080p @ 56 Hz */
60, 1920, 1080, 7692, 100, 40, 30, 3, 10, 2, 0, FB_VMODE_NONINTERLACED, 0
The user can modify this default setting for their case.
Specially, there are some risks to use 1080p@60 video mode for imx6qp-sabresd. The hdmi device will has no valid hdmi signal output in this case. For example,
/* 1080p @ 60 Hz */
60, 1920, 1080, 6734, 148, 88, 36, 4, 44, 4, FB_SYNC_HOR_HIGH_ACT | FB_SYNC_VERT_HIGH_ACT, FB_VMODE_NONINTERLACED, 0
The user sholud set these values according to hareware parameters.
No ratings
Version history
Last update:
‎02-01-2016 03:02 AM
Updated by:
