This document explains how to configure a cross compiler running in iMX6Q. The target is the Kinetis L family. For the iMX6Q, Yocto is used to generate the iMX6Q image.
Basic knowledge of Yocto and Linux is required. The steps explained were performed for the iMX6Q SABRE-SD and the Freedom KL25. Installation of Yocto in your host system is needed too.
The chosen method to configure the cross compiler for the Kinetis L, needs a native compiler that will run in the iMX6Q. Below are the general steps:
The iMX6Q image needs certain packages in order to configure and generate correctly the cross-compiler. After setting up the environment and chose the MACHINE the below lines added in the local.conf file to install those packages in our rootfs:
IMAGE_INSTALL_append = " gcc g++ binutils libgcc libgcc-dev libstdc++ libstdc++-dev libstdc++-staticdev gawk gzip perl autoconf automake libtool gettext gperf tcl guile gmp mpfr make m4 texinfo flex bison git"
The image to generate is the core-image-minimal:
bitbake core-image-minimal
Once the building is finished, a native compiler for the iMX6 and other packages needed to configure the Kinetis Compiler should be added to the Yocto image.
The arm cross compiler version was gotten from CodeSourcery. arm-2011.03-42-arm-none-eabi is used in this document.
You can get the source code by:
Once the image was built, boot the imx6 board with this image. Copy the source code (arm-2011.03-42-arm-none-eabi.src.tar.bz) in your target that is running Linux and extract the files.
For example, a new folder was created in /home/root directory:
$ mkdir gcc_test
$ cd gcc_test
And extract the files in this folder:
$ tar –jxvf arm-2011.03-42-arm-none-eabi.src.tar.bz2
$ cd arm-2011.03-42-arm-none-eabi
Create a source and a build folder:
$ mkdir source build
Move all the files to the source folder:
$ mv *.tar.bz2 source/
Create a new folder in /opt where the kinetis cross compiler will be installed
$ cd /opt
$ mkdir arm-none-eabi
To configure, build and install the compiler these general steps are followed for certain packages:
Create an environment variable that will specify where the cross compiler will be installed:
$ export INSTALL_PREFIX=/opt/arm-none-eabi
Extract the gmp files:
$ cd ~/gcc_test/arm-2011.03-42-arm-none-eabi/source
$ tar –jxvf gmp-2011.03-42.tar.bz2
Create a new folder in build directory. This folder will contain a generated Makefile that will be used to build and install the package:
$ cd ../build
$ mkdir gmp
$cd gmp
Configure the package:
$ ../../source/gmp-2011.03/configure --prefix=$INSTALL_PREFIX --build=arm-poky-linux-gnueabi CC=arm-poky-linux-gnueabi-gcc CXX=arm-poky-linux-gnueabi-g++ --disable-newlib-supplied-syscalls --disable-libgloss --disable-nls --disable-shared
Build and Install the package
$make
$make install
Extract the mpfr files:
$ tar –jxvf mpfr-2011.03-42.tar.bz2
$ cd ../build
$ mkdir mpfr
$cd mpfr
$ ../../source/mpfr-2011.03/configure --prefix=$INSTALL_PREFIX --build=arm-poky-linux-gnueabi --target=arm-none-eabi CC=arm-poky-linux-gnueabi-gcc CXX=arm-poky-linux-gnueabi-g++ --with-gmp=$INSTALL_PREFIX --disable-shared
$make
$make install
Extract the mpc files:
$ tar –jxvf mpc-2011.03-42.tar.bz2
$ cd ../build
$ mkdir mpc
$cd mpc
$ ../../source/mpc-0.8.1/configure --prefix=$INSTALL_PREFIX --target=arm-none-eabi --build=arm-poky-linux-gnueabi CC=arm-poky-linux-gnueabi-gcc CXX=arm-poky-linux-gnueabi-g++ --with-gmp=$INSTALL_PREFIX --with-mpfr=$INSTALL_PREFIX --disable-shared
$make
$make install
Extract the binutils files:
$ tar –jxvf binutils--2011.03-42.tar.bz2
Create a new folder in build directory. This folder will contain configure the package:
$ cd ../build
$ mkdir binutils
$cd binutils
$ ../../source/binutils-2011.03/configure --prefix=$INSTALL_PREFIX --target=arm-none-eabi --build=arm-poky-linux-gnueabi CC=arm-poky-linux-gnueabi-gcc CXX=arm-poky-linux-gnueabi-g++ --with-gmp=$INSTALL_PREFIX --with-mpfr=$INSTALL_PREFIX --with-mpc=$INSTALL_PREFIX --disable-nls --disable-werror
$make MAKEINFO=true
$make install MAKEINFO=true
Extract the gcc files:
$ tar –jxvf
$ cd ../build
$ mkdir gcc
$cd gcc
$ ../../source/gcc-4.5-2011.03/configure --prefix=$INSTALL_PREFIX --target=arm-none-eabi --build=arm-poky-linux-gnueabi --host=arm-poky-linux-gnueabi CC=arm-poky-linux-gnueabi-gcc CXX=arm-poky-linux-gnueabi-g++ --enable-languages="c" --with-gnu-ld --with-gnu-as --with-newlib --disable-nls --disable-libssp --with-newlib --without-headers --disable-shared --disable-threads --disable-libmudflap --disable-libgomp --disable-libstdcxx-pch --disable-libunwind-exceptions --disable-libffi --enable-extra-sgxxlite-multilibs --with-gmp=$INSTALL_PREFIX --with-mpfr=$INSTALL_PREFIX --with-mpc=$INSTALL_PREFIX
$make
$make install
To test the Cross compiler it is necessary to add the path of the installation to the PATH variable.
$ export PATH=/opt/arm-none-eabi/bin/:$PATH
To check the version of the cross compiler:
$ arm-none-eabi-gcc –version
arm-none-eabi-gcc (GCC) 4.5.2
Copyright (C) 2010 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE
Attached you can find a folder that contains a simple KL25 example that can be compiled in the iMX6 and then flash the Freedom KL25 with the OpenSDA. This means that you have to attach the USB OpenSDA to the OTG port of the iMX6 board.
Type the next in the hello folder (/Kinetis GNU/KL25_TEST/KL25/hello)
$make clean
$make
This will generate a main.srec file that can be copied to the USB MSD device featured by the OpenSDA.
$cp main.srec /meida/sda1
$sync
After this, the RGB LED in the Freedom KL25 will toggle.
Original Attachment has been moved to: KL25.tar.zip
gusarambula, CarlosCasillas, jamesbone, jimmychan would you be nice enough to skim through the document and share your comments?
The document looks very good! I think it's very well structured although I would add an index just to have an easier way to jump to a particular package installation for example.
What is the main idea for doing this "Kinetis-L Compiler in the iMX6Q" ? I think it is better to point out why need to make the Kinetis-L Compiler in i.MX6Q.
Thanks Jimmy you have a good point. We have seen many development tools like Udoo and other that use the imx6 even as host to program a smaller device like Kinetis-L.
Nice document Alex, good structure and content. Have you considered adding some "graphical attractive" like pictures or videos of demo applications working?
