How to use amixer to change freely between Headphone and Spk for L3.0.35 wm8962 codec
Add kcontrol API for Headphone Jack and Spk for WM8962, from this kcontrol, you can use amixer to change freely between Headphone and Spk.
The names of the mixers
1: HP Function
2: SPK Function
amixer controls:
numid=62,iface=MIXER,name='HP Function'
numid=63,iface=MIXER,name='SPK Function'
1:
How to enable HeadPhone using this Kcontrol:
amixer cget numid=62
   ; type=ENUMERATED,access=rw------,values=1,items=2
   ; Item #0 'off'
   ; Item #1 'on'
   : values=0
amixer cset numid=62 1 //enable HP
   ; Item #0 'off'
   ; Item #1 'on'
   : values=1
2:
How to enable Speaker using this Kcontrol:
amixer cget numid=63
   ; Item #0 'off'
   ; Item #1 'on'
   : values=0
amixer cset numid=63 1 //SPK enable
   ; Item #0 'off'
   ; Item #1 'on'
   : values=1
添付
評価なし
バージョン履歴
最終更新日:
‎07-06-2014 10:57 PM
更新者:
