We tried importing the SDK example "wifi_mqtt" and found the "mqtt_client_info" structure, it doesn't seem to enable the security in the default example, please see the following screenshot.
Referring to the sample code, it needs enable the "LWIP_ALTCP " & "LWIP_ALTCP_TLS" macros to enable security. Do you know how to enable security? or do you have a guide for opening "LWIP_ALTCP " & "LWIP_ALTCP_TLS" macros using the wifi_mqtt example?
Trevor
I check internally about this, and I'm afraid that we currently do not have an example with those features enabled . In this case there are some macros that can be enabled still, it will be up to every customer to adapt the examples and add the features.
I apologize for the inconvenience
