Hello!
I am using the AHI to interface with the radio, but I do not see a way to set the power level. I need to set the output power to the maximum that the radio can transmit.
First I run vAHI_HighPowerModuleEnable(1, 1) to set the radio in high power mode.
However, I do not then have a way to set the power. I found the call "bAHI_PhyRadioSetPower", but this fails in the linking step (even though other AHI functions work fine).
Unfortunately I know that I need to set a higher output because the signal only reaches a few dozen meters through open unobstructed space with my current settings.
Any help here would be appreciated. Thanks in advance!
You enter this questions internally, and you got a reply.
Did you solve your issue?
Mario
