I'm working with FRDM-KW41Z and FRDM-K64F+FRDM-CR20A Border Router but KW41Z can't join the network(FRDM-KW24D can join).
Isn't there interoperability between Kinetis Thread Stack 1.1 and 1.0.1?
BR,
Nori Shinozaki
If both MCU have the same Thread spec software, you shouldn't have a problem with a mixed platform network. I think the issue is the software versions you are using.
The KW41z public Thread release comes with Thread v1.1 spec.
I'm guessing you are using a beta version for the FRDM-K64F+FRDM-CR20A software that is Thread v1.0 spec.
We are internal testing a Thread v1.1 spec release that will be ready by mid January. Once we launch this software you will be able to have FRDM-K64 border router with FRDM-KW41 devices
Hello aleguzman,
Thanks again, yes I'm using a beta version for FRDM-K64F+CR20A.
Hope to get a next release soon!
Nori Shinozaki
