I had installed BeyondStudio for NXP a week ago. I was following BeyondStudio for NXP installation guide and when i reached section 1.2.3 i wasn't able to install the two mandatory plugins. The output says: "The operation cannot be completed" followed by:
Cannot complete the install because one or more required items could not be found.
Software being installed: NXP ZBPro Configuration Editor 2.0.0 (com.jennic.sdk.zbpro.external.feature.feature.group 2.0.0)
Missing requirement: ZBPro Config Edit Support 2.0.0 (com.jennic.zps.configeditor.edit 2.0.0) requires 'bundle org.eclipse.emf.edit 0.0.0' but it could not be found
Cannot satisfy dependency:
From: NXP ZBPro Configuration Editor 2.0.0 (com.jennic.sdk.zbpro.external.feature.feature.group 2.0.0)
To: com.jennic.zps.configeditor.edit [2.0.0]
Then i tried uninstalling BeyondStudio as @mario_castaneda suggests on this forum post but nothing changed.
What gives?
解決済! 解決策の投稿を見る。
Hello @ffonck96
Hope you are doing well.
Please, take a look at the document that is attached to this post, there you can find the steps that I followed to replicate this behavior and how to try to solve it.
Eduardo.
Thanks for the reply @EduardoZamora , it worked!.
Although, part of my issue is solved I'm still wondering if Jennic RTOS Configuration Editor is available for install.
Thanks for the file it was useful, regards!
It seems that the Eclipse cloud has changed the structure of multiple dependencies packages in their repository, making older plugin versions no longer available for Beyond Studio IDE.
I apologize for any inconveniences this might cause you.
Eduardo.
Hello @ffonck96
Eduardo.
